2024-04-30 8:26 AM
Hello!
I have not been able to figure out how to get PSSI DMA working for the H5. For other peripherals, there is a DMA-tab in the configuration, but not for PSSI. Similarly, I have not been able to find any way of using interrupts for transmitting or receiving PSSI data. The XXX_Transmit_IT() & XXX_Receive_IT() functions available for many other peripherals are missing. As it is, my only option seems to be to synchronously send and poll for data.
My question is what am I missing? Is there another way of doing this for the STM32H5? If you could just point me in the right direction, I'd be most grateful.
Cheers,
// Ola
2025-03-06 3:23 AM
STM32CubeIDE 1.18 contains STM32CubeMX 6.14 and now there is a DMA Settings in the PSSI configuration tab and in the GPDMA1 config UI PSSI_RX and PSSI_TX are available in the drop-down menu CH0 / Request Configuration / Request.
From a quick glance, the generated code looks sane - just a tad confusing because there is no GPDMA1_REQUEST_PSSI and GPDMA1_REQUEST_DCMI is used which I guess is due to that according to AN5593 rev 7, you can't use PSSI and DCMI at the same time.
I haven't tested it on an actual STM32H5 though.
