2014-08-31 9:51 AM
I make the charger from the solar panels with automatic orientation to the sun. There is a problem after device reset, reset to zero RTC. What can cause, reset clocks?
2014-08-31 10:37 AM
Powering or coding? I'd perhaps not put all the weight cantilevered onto the servo shaft, and had a shaft/bearing arrangement with a belt/gear drive from the servo.2014-08-31 11:57 AM
Reset causes the program. after resetting cpu the rtc reset to zero.
This experimental device for debugging codes. )) I will remake mechanics later. thanks for the adviceWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
