2016-09-09 1:14 PM
Hi.
Is it possible to do some computation in parallel in CPU (with integers) and FPU (with floats)?Probably not, because both units need their own instructions to perform a math operation and the instructions can only be executed sequentially one after another.2016-09-10 1:11 AM
I would consult the
http://infocenter.arm.com/help/topic/com.arm.doc.ddi0439c/DDI0439C_cortex_m4_r0p1_trm.pdf
or similar for such details. Since a normal cycle count figure is given for FPU instructions as well, I assume they are basically executed sequentially with ''normal'' instructions, even if the FPU is implemented as a kind of coprocessor.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
