2018-07-08 6:06 AM
Hi Everyone,
I am thinking of designing wireless home automation product using IoT. Can anyone suggest which STM32 series is suitable for this application. I have knowledge in stm3f4 series. So i can easily learn whatever series which is suitable my application.
#stm32-nucleo-64 #stm32-c2c2018-07-08 6:14 AM
You may want to see this board to see if it meets your needs:
https://www.st.com/en/evaluation-tools/b-l475e-iot01a.html
Actually two versions of this board exit (different radio types).
If you think about F4 line, consider the L4 (newer, low power, etc). The board above uses L4 MCU.
2018-07-08 6:21 AM
It is a multi-faceted decision, and going to be dependent on your exact requirements.
For new designs consider the L4(+) or F7 depending on the amount of horse-power your application needs.
2018-07-08 5:37 PM
if you would like a complete solution in one Dev board, you could look at the B-L072Z-LRWAN board.
F series, Vs L series, Vs F4 , when I use the cube it is all seamless....
any chip/board will do... depending on your power budget.
