2025-05-21 9:09 PM
1. In order to calculate the values of pull up & pull down resistor, in which section can we find the impedance information?
2. Should we use external crystal for OSC_IN & OSC_OUT pins?
3. If we are using USB2.0 FS feature what is the reference?
Thanks,
2025-05-22 4:22 AM
1) In the datasheet under "I/O port characteristics". It's about 40 kOhm.
https://www.st.com/resource/en/datasheet/stm32h743bi.pdf
2) It is up to you. A crystal is not required for USB device operation.
3) I don't understand the question. Are you looking for the reference manual?
It would have been better to mention the chip you're using rather than just the family. The H7 has a lot of different models.
2025-05-22 4:32 AM
@Meghna wrote:3. If we are using USB2.0 FS feature what is the reference?
What do you mean by, "the reference"? For what chip?
Go to the 'Documentation' tab on the chip's Product Page, and search for "USB" ... ?
