2016-11-03 8:08 AM
Hi I am triyng to use multiple MPU9250�s with Motion Driver 6.12 with STM32F4 Discovery. I am using TCA9548A 8 channel i2c multiplexer.
In arduino solution
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);Wire.endTransmission();code block is being used.
But I can not find the equivalent code in Motion Driver 6.12 in IAR Embedded Workbench.
Does anyone has experience about this.
Best regards,
#i2c-multiplexer2016-11-04 3:57 AM
Maybe you should contact IAR support, they can help you on this topic.RegardsWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
