2021-12-16 7:04 PM
2021-12-16 7:20 PM
The Reference Manual has the map of memory regions and is the best source of info for the chip. See "Memory map and register boundary addresses".
Seems like a lot of work when you can just use existing solution for this. Your IDE of choice should have a solution.
2021-12-16 7:20 PM
2021-12-16 7:36 PM
Thank you for your help. I got the answer for my question.
I am using KEIL for this project, Yes I can use the existing solution for the memory mapping.
