2020-07-27 1:21 AM
Hi!
I'm trying to lock internal flash on STM32L4RZI MCU from writing, to disallow software to write on itself.
I use ST-Link utility, and when I lock at least one sector(In option bytes window), The flash is erased and then lock the wanted sector.
I tried the same method on another MCU - STM32L433RC, and it works fine.
I'm not sure what the problem is, but if there is any solution, or locking flash is impossible in this MCU, i would like to know.
Thank you!
2020-08-12 3:48 AM
Hi @SReef.1 ,
Did you tried using STM32CubeProgrammer or the example STM32Cube_FW_L4\Projects\NUCLEO-L4R5ZI\Examples\FLASH\FLASH_WriteProtection?
Please let me know if the same problem is faced with these 2 methods as well?
-Amel
