2009-02-22 3:09 AM
How to, 9bit SPI for a LCD
2011-05-17 3:52 AM
Please use synchronous mode of USART. Details are described in section 24.3.8 of RM0008.
2011-05-17 3:52 AM
I try to interface the same LCD on a STM32f103RB and I have already test your method to send the ninth bit. But I can't manage the LCD. I think I have a problem with the SPI setting. Can you tell me how you have configured the SPI ? Thank you in advance :p PS : This is my actual SPI configuration : - no bidimode - no CRC - 16-bits data frame format - Full duplex - Software slave management disable (I use the GPIO to set and reset NSS) - MSB transmitted first - fPCLK/256 - CK to 1 when idle and the second clock transition is the first data capture edge2011-05-17 3:52 AM
Hi Philippe,
Source code to drive this LCD can be found here: http://gravitech.us/MicroResearch/Others/LCD6100/LCD6610_NPX_STM32F103.zip Frank2011-05-17 3:52 AM
Hi Frank,
Thanks to you I managed to use the LCD :-] Thank you again ! Kind regardsWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
