2023-05-29 3:22 AM
I have set the timer4 in center alligned mode 3 and I want to trigger ADC on counter overflow. If I understand correctly the ADC trigger input TIM4_TRGO can be set in timer configuration as update event output but that means also in underflow will send the timer a trigger for conversion.
Do you know any solution?
2023-10-25 6:59 AM
I didn't received any Feedback, I found a workaround for my issue but I would like to review with you and be sure that is not a bug in hardware or I am wrong, could you help me?
