2014-11-26 9:20 AM
Hi!
Keil MDK Lite V5.12 I cannot tell why the debugger cannot breakpoint certain rows. Like a CAN_Transmit function. Not only will put an exclamation mark, it will jump over it completely. This function is that time-sensitive that you cannot break it? Nor breakpoints inside the function will be called. The code just simply jumps over that part. Why? I can link the code, if needed, though I doubt the ''problem'' is a particular one. Rather my lack of knowledge. Thank you! #exclamation #breakpoint2014-11-26 10:04 AM
Turn off optimization, that way there will be a more simplistic one-to-one linear code flow.
