2020-11-18 8:47 AM
Listening on TCP/IP port 2331
Connecting to target...
Connected to target
Waiting for GDB connection...Connected to 127.0.0.1
Reading all registers
Read 4 bytes @ address 0x08002050 (Data = 0x46206008)
Read 2 bytes @ address 0x08002050 (Data = 0x6008)
Loading RTOS plugin: C:\ST\STM32CubeIDE_1.4.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.jlink.win32_1.4.0.202007081208\tools\bin\GDBServer\RTOSPlugin_FreeRTOS.dll...
RTOS plugin (API v1.0) loaded successfully
RTOS plugin: Loaded
Received symbol: pxCurrentTCB (0x200006E8)
Received symbol: pxReadyTasksLists (0x200006EC)
Received symbol: xDelayedTaskList1 (0x20000B4C)
Received symbol: xDelayedTaskList2 (0x20000B60)
Received symbol: pxDelayedTaskList (0x20000B74)
Received symbol: pxOverflowDelayedTaskList (0x20000B78)
Received symbol: xPendingReadyList (0x20000B7C)
Received symbol: xTasksWaitingTermination (0x20000B90)
Received symbol: xSuspendedTaskList (0x20000BA8)
Received symbol: uxCurrentNumberOfTasks (0x20000BBC)
Received symbol: uxTopUsedPriority (0x00000000)
Received symbol: uxTopReadyPriority (0x20000BC4)
Received symbol: vPortEnableVFP (0x08006F20)
Received symbol: FreeRTOSDebugConfig (0x00000000)
All mandatory symbols successfully loaded.
Reading 64 bytes @ address 0x07070700
WARNING: Failed to read memory @ address 0x07070700
WARNING: Failed to read memory @ address 0x07070723
WARNING: Failed to read memory @ address 0x0707070B
Received monitor command: WriteDP 0x2 0xF0
ERROR:Writing DAP register failed
Read register 0 (4 bytes) from DLL: 1A980400
Read register 1 (4 bytes) from DLL: 4C000020
Read register 2 (4 bytes) from DLL: 02020202
Read register 3 (4 bytes) from DLL: 03030303
Read register 4 (4 bytes) from DLL: 00000000
Read register 5 (4 bytes) from DLL: 05050505
Read register 6 (4 bytes) from DLL: 06060606
Read register 7 (4 bytes) from DLL: 07070707
Read register 8 (4 bytes) from DLL: 08080808
Read register 9 (4 bytes) from DLL: 09090909
Read register 10 (4 bytes) from DLL: 10101010
Read register 11 (4 bytes) from DLL: 11111111
Read register 12 (4 bytes) from DLL: 12121212
Read register 13 (4 bytes) from DLL: 18A80020
Read register 14 (4 bytes) from DLL: 47200008
Read register 15 (4 bytes) from DLL: 50200008
Read register 16 (4 bytes) from DLL: 00000001
GDB closed TCP/IP connection (Socket 580)
GDB closed TCP/IP connection (Socket 556)
2020-11-18 2:28 PM
Do you have an ST chip or a knock off of unknown origin?
2020-11-19 7:03 AM
there is no stm32f407 fackery topics on the web. there is ST trade mark on the chip I see. And I have debuged it in keil, it can run.
I am a freshman on stm32 and cubeide, could you tell me what is it doing reading addr 0x07070700 and 0x07070723.
