2018-01-30 4:46 PM
so, i've updated cube to v4.24.0
and it starts to make broken .ioc files
i tried several ways to reproduce same issue and here's the problem.
1. make a project with stm32f407ze ( not sure it's because of this but.. )
2. make CAN1 and CAN2 as master mode and slave mode.
3. go to configuration and open up CAN1 setting
4. make Time quanta BS 2 as 7
5. make prescaler to 4
6. make Time quanta BS 1 as 10
7. press okay and save project.
( at this point, you can't open up CAN1 configuration window )
8. and now project is unreadable
my solution to fix this is to manually modify ioc file, removes CAN related configuration
2018-02-01 3:00 AM
Hello
joebk
,We raised this issue internally to CubeMX team.
Thank you for highlighting it, and Sorry for the inconvenience it may bring.
Best Regards,
Imen.
2018-02-01 6:02 AM
Hi
joebk
,You are right, we can reproduce the same behavior.
This issue will be fixed next release.
Best Regards,
Imen.
2018-02-21 1:27 AM
Sorry for the inconvenience. This problem will be solved in next STM32CubeMX 4.25 release coming out in few weeks from now.
