how to reduce inrush current when stm32 powering up?
Hi,As the title described, how to mitigate the current behavior when stm32 is applied power? My commercial power system are quite sensitive when MCU is power on.For example, let stm32 enters into low power mode once power is on and then control the c...
JKW by Associate III
  • 11575 Views
  • 21 replies
  • 13 kudos
Data-like flash read with memory barrier?
Heyho,I recently finished - or so I thought - the ethernet bootloader for STM32H73x.The bootloader can update the application and vice versa, updating, jumping back and forth, all working fine.Until yesterday all of a sudden (when I was working on so...
LCE by Principal II
  • 8920 Views
  • 22 replies
  • 9 kudos
TARGET_HELD_UNDER_RESET
Hello, im using STM32f410CBT3 on custom board. I was able to debug before, but now Im getting errors trying to conect to STM32 using stlink v3 set with isolation. Sometimes i can read data, but it is corrupted (all 0, but i didnt flashed it yet). Tri...
zsx by Associate II
  • 3814 Views
SRAM2 read error from DAP in STM32L496
When reading SRAM2 memory in STM32L496 using ST-Link V2 debug probe, incorrect values are received when read crosses 1k (1024 bytes) boundary. For example, when I try to read 32 bytes starting from 0x100003F0, last 16 bytes that start from 0x10000400...
IIvan.22 by Associate III
  • 4014 Views
