I2C Master Error Interrupt Not Firing - STM32F407
Posted on March 18, 2013 at 15:42Hi All I have a driver for I2C master mode which has been working correctly under normal conditions. It is interrupt driven so the interrupt fires for each received/transmitted byte. If however non-present slaves are...
hpipon957 by Associate III
  • 1707 Views
F4Discovery SPI troubles
Posted on July 05, 2012 at 14:42The original post was too long to process during our migration. Please click on the attachment to read the original post.
OPTIMIZATION
Posted on March 18, 2013 at 11:51hiin my project with RIDE7, when i use ''No optimization'' I can't use debugger but when i use size optimization I have a problem in some functions . can I use No optimization juste when I call this functions? #fl...
aymen by Associate II
  • 4587 Views
  • 13 replies
PWM Time shifting signal
Posted on January 08, 2013 at 11:55 Hi, I program a PW M sig nal in PB4 port using TIM3 using this program int main ( void ) { while (1) { TIM3->CCR1 = 1000 ; } } /*____________________________TIM3_______________________...
bmwael1 by Associate II
  • 1868 Views
SPI pins initialization STM32L-discovery
Posted on October 08, 2012 at 16:06It seems I can't correctly initialize the SPI pins on the STM32L-discovery board. I have very little experience with programming 32bit devices so I am probably missing something obvious. I hooked up my oscilloscope...
jurriaan by Associate II
  • 3732 Views
DFU combine with project.
Posted on March 06, 2013 at 02:08Hi All,Could the DFU project possible to merge with my project in one hex file?
cng by Associate II
  • 1523 Views
Programming languages
Posted on March 19, 2013 at 13:31Hello, I´m new in programming STM32, so I´m sorry for ''stupid'' question. It´s possible to program STM32 microcontrollers by objected oriented languages (C++, Java,...). I know that using C is the best choice, bu...
j3lda by Associate II
  • 1387 Views
STM32F3DISCOVERY USB-Virtual Com Port?
Posted on November 18, 2012 at 14:16Hi!May I ask for help about setting up VCP with one?I am currently looking over the files of STM32_USB-FS-Device_Lib_V3.4.0 (under virtual com port). I can't seem to understand how to tailor it with STM32F3Discove...
bobot by Associate II
  • 4859 Views
  • 18 replies
