I2C slave not ACK
Posted on January 14, 2014 at 21:59 </p> I have an issue with STM32F0 Discovery. I am using I2C1 (like master) to send start condition and address to I2C2 (slave) on the same board. I am able to generate propertly the signal but the IC2 (slave...
Unable to program STM32F1x using the ST-link/openOCD
Posted on January 09, 2014 at 12:31Hello, I like to program my STM32F103 with the ST-link/V2 device by using openOCD. However I got next message: Error: flash write failed at address 0x80016f8 Error: error writing to flash at address 0x08000000 at o...
evert2 by Associate II
  • 4384 Views
STM32F103 USB VCP receives only byte by byte
Posted on January 17, 2014 at 13:08Hello, Maybe anyone have met with situation or have any hints where to look for problem if I receive data in ''EPx_OUT_Callback()'' function only by one byte, even if it was sent significantly larger amount of it. ...
lauris by Associate III
  • 746 Views
STM32F4 Discovery with ADS7870 (TI) ADC
Posted on January 15, 2014 at 10:19 Hi, I'm trying to communicate between the http://www.ti.com/product/ADS7870and the ST microcontroller STM32F4 Discovery evaluation board. I'm using IAR and at the moment I'm just trying to read register 31 fro...
camila by Associate II
  • 7905 Views
  • 20 replies
Speeding up VCP OTG USB communication
Posted on January 16, 2014 at 12:29Hi there!I'm trying to transfer as much ASCII as possible from my STM32F4Discovery board.Basically I'm doing this:while (1) {   APP_Rx_Buffer[APP_Rx_ptr_in]=APP_Rx_ptr_in;   APP_Rx_ptr_in++;   if(APP_Rx_ptr_in == A...
tszewczyk by Associate II
  • 2751 Views
Standalone STM32L152CC guidance
Posted on December 20, 2013 at 09:03Hello, I will be making (or trying to make) my own custom board with STM32L152CC (LFP48 package). I have successfully implemented my application on the STM32L152RC Discovery board using:  - 3 GPIO pins for PWM  -...
klemen by Associate II
  • 1971 Views
STMTouch & Shield
Posted on January 09, 2014 at 21:26What exactly does marking a pin as SHIELD do? #tsi-stmtouch
msinger by Associate
  • 1053 Views
How to fix CPAL timeout problem
Posted on January 16, 2014 at 05:33Hi, My problem is similar to the following: https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/CPAL%20Spin%20Waits%20in%20Interupt My device used to freeze and have watchdog triggered. I found that...
jhnlmn by Associate III
  • 1734 Views
