Cube for STM32F2
Posted on March 04, 2014 at 15:31Is there a planned release date for the Cube for the STM32 F2 series?
Multiplexing SRAM,NOR Flash and NAND Flash ?
Posted on April 26, 2014 at 01:36Guys, How can I multiplex SRAM,NOR Flash and NAND Flash on PD7 ? It's function as PD7 FSMC_NE1/FSMC_NCE2 on pin 88 for STM32F103VCT6, is it configurable via software or I need to put a latch / multiplex chip for it ?...
STM32 truncated documentation
Posted on April 28, 2014 at 08:19Hello there,I was looking for the STM32F103RB datasheet but all i found is some 105 pages truncated document with only overview of the device. I was looking for something more like 1005 pages. I looked deeper into th...
STM32f407 external pulse counter channel selection
Posted on August 21, 2013 at 12:06 Hi guys, I am having a big problem; I would like to count external pulses with 2 timers; TIM 2 and TIM5. The problem is, that I need to connect my two timers to the 2 I/O pins that are free. So th...
anze by Associate
  • 5410 Views
  • 12 replies
TIM_OCMode_Toggle PWM Duty Controll
Posted on October 05, 2013 at 08:36I'm an absolutely beginner in microcontrollers. I want to create a PWM signal wave signal  to drive main power switch at 100Khz TIM1CH1&TIM1CH1N of   STM32F103VC. I change duty (CCR1_Val) but the duty stay same at...
stm3223 by Associate II
  • 8100 Views
  • 15 replies
Scary java crash in CubeMX
Posted on April 23, 2014 at 14:39When you enable any part in the ADC (F401RET 64pin mcu) you get a java-crash:Apr 23, 2014 2:03:11 PM com.st.microxplorer.util.LogicalParser checkConditionSEVERE: nullcom.bestcode.mathparser.ParserException: ExpNtVld ...
belhage by Associate
  • 1066 Views
independent DAC Channel triggers on STMF3XX
Posted on April 21, 2014 at 07:55Hi,I am using STM32F303 to generate 2 sine-waves  on DAC_Channel1 and DAC_Channel2.I use one lookup table to generate the sine-wave. And I succeded to generate sine-waves on both channels, but the generated signals h...
bugra by Associate II
  • 1519 Views
