SPBT footprint
Posted on May 26, 2014 at 05:41The SPBT2632C1A is the larger footprint, which is fine for our purposes.  The datasheet does not make any mention of what the 6 extra pads on the bottom are for, yet there is a warning that''thou shalt not ground extra...
litteka by Associate
  • 1050 Views
USART2 TX Problem stm32f4
Posted on May 26, 2014 at 02:23Hello, I am having a problem with my STM32F4 USART2. the problem is throwing me this bullshit and can not find where the error may be. #include ''stm32f4xx.h''                  // Device header#include ''stm32f4xx_gpio...
japifer by Associate
  • 963 Views
emide on STM32f
Posted on May 25, 2014 at 12:27hello I am trying to use emide on STM32f100c8 , but I am facing some problems specifically with integration and linking with STM32F10x_StdPeriph_Driver ?and now I am stuck with errorobj\Debug\Src\STM32F10x_StdPeriph_Dr...
Point to a char array for displaying on LCD?
Posted on May 24, 2014 at 16:27 Hi, i have a bmp085 bosch pressure&temp sensor, wich i want to show my data in format 4 degree The raw readings are ok, i have the following code going uint8_t tlsb; uint8_t tmsb; uint16_t t...
Bogdan by Senior
  • 1633 Views
STM32F429, Display Horizontal String Using Lcd Library
Posted on May 22, 2014 at 00:23Hi,I'm using STM32F429 and working with the lcd. i want to display a string horizontally at lcd. First i have used the segger's  gui, it was easy to display horizontal with using gui. But i decided to use the lcd.h for...
STM32F429 Debug Viewer Usage
Posted on May 21, 2014 at 12:57Hi, i'm working on stm32f429 with keil uvision v5. I came up to some discussions about debug viewer at keil forums(like this http://armcortexm.blogs.upv.es/stm32f4-discovery-and-printf-redirection-to-debug-viewer-in-ke...
input capture help or other suggest
Posted on May 20, 2014 at 01:21hello I am using STM32f100C8 on this controller implemented : Tim4 that work as global clock for all the functions (generating ticks and counter with  flags compare to seconds )Tim3 work as PWM but it implemented man...
