how to calculate coefficients in matlab?
Posted on June 05, 2014 at 20:53hi, im going to design and IIR biquad filter in matlab FTDTOOL and use generated coefficients in cmsis dsp function arm_biquad_cascade_df1_f32 () .i design an IIR filter for example 8th order and set filter arithmetic...
USB Full Speed question
Posted on July 28, 2014 at 09:05Hey guys, I'm using USB Full Speed in CDC with a computer. Everything works well but I would like to increase the throughput by using DMA.I never see any examples of this, I don't know if it's possible ... My opinion ...
STM32F3 and external SPI Flash, how programing?
Posted on July 28, 2014 at 07:19I would like touseExternalSPIflashmemoryas storage forpicturesonLCD.Looking fora way tofill theexternalFlashcontentwhen programmingthe processorusing the programmer(J-LINK)viaSWDwhen youupgradefirmwareviabootloader (U...
asrock70 by Associate II
  • 945 Views
PWM synch
Posted on July 25, 2014 at 22:38How to Synch my PWM signal to the rising edge of an external signal. i.e The rising edge of my external signal should be on in synch with the leading ege of my PWM. I am using STM32F4 discovery board.Thanks #mow-my...
stm32f407IG and USB3317
Posted on August 21, 2013 at 10:31Hii designed schematic for stm32f407 and usb 3317 but i dont know how to connect their port together...please help me...Thanks
nima by Associate II
  • 3975 Views
ADC reading change rapidly
Posted on July 25, 2014 at 00:44In �?y ADC, I use __IO uint32_t uhADCxConvertedValue, but the re�?ding ch�?nge r�?�?dily even th�?ugh the re�?l v�?lt�?ge d�?es n�?t ch�?nge, which is �?.854�?�?.855. Ple�?se hel�?
Linda by Associate II
  • 1902 Views
DSP Sampling Rate, FFT Size, and Buffer Size
Posted on July 25, 2014 at 21:46Hi, Can someone please throw some ideas on what might be the problem with what I am seeing  / doing. Here are the relevant details. 1 - Using an STM32F407 processor (Discovery PCB), clock at 168Mhz 2 - Using ADC to sa...
STM32F3 system memory and bootloading
Posted on July 25, 2014 at 10:33Hi, I'd like to program STM32F373s via their usart1 from an STM32F2, though the latter should be irrelevant, I think. The board has the STM32F2 controlling four STM32F373 processors as peripheral controllers and talks...
REGARDING STM32F030F4P6 GPIO configuration.
Posted on July 24, 2014 at 05:13HI,I have faced one problem with PORTF pin configuration (PF0,PF1).My GPIO configuration:RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOF, ENABLE); InitGpio.GPIO_Pin = (GPIO_Pin_0 | GPIO_Pin_1 ); InitGpio.GPIO_Mode = GPIO_Mo...
chowdaiah by Associate II
  • 3334 Views
interfacing external oscillator to STM32F407igt6
Posted on July 25, 2014 at 12:44Hi all,         I have to interface external oscillator to stm32f407igt6 which is having 16Mhz internal frequency and i need to boost it to 168Mhz frequency by connecting a 25Mhz external  oscillator so can anyone giv...
ecmanja by Associate II
  • 1398 Views
