STM32F05 ADC Disscusson
Posted on December 26, 2014 at 06:56 Dear All, I started STM32F0 ADC configurations select independent conversion mode (single) ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; But my CMSIS stm32f0xx.adc.c file does not have...
pic_micro by Associate II
  • 1847 Views
stm32f091RB
Posted on December 26, 2014 at 13:31hello everybodybefore starting to explain my problem, I wish to inform you that I am a beginner, and also I'm sorry for my English.I'll buy a STM32F091RB MCU and I have not found an IDE to program nor a tool to do...
rafik by Associate II
  • 1709 Views
STM32F415RGT6 power scheme
Posted on December 25, 2014 at 22:10Hello,I am engineering new PCB. It is little bit unclear from datasheet so I would like to know if my power supply scheme is correct, especially decoupling capacitors.Thank you very much! #stm32-f4-power-supply...
zexx86 by Associate II
  • 1324 Views
STM32F072 datasheet APB2 reference?
Posted on December 26, 2014 at 04:58Hi everyoneSo I've been trying to find reference on the datasheet of the STM32F072RB for the APB2 but with no avail.I am talking about this one http://www.st.com/st-web-ui/static/active/en/resource/technical/docum...
USART1 with STM32F0 Discovery
Posted on December 22, 2014 at 17:14 Dear All, I write a program for USART1 of STM32F0 Discovery board. I am sure that my hardware is working . I configured with PuTTY but it does not display the message Please advice PA10 RX to...
  • 3865 Views
  • 11 replies
stm32f429i_disco ILI9341 driver
Posted on December 26, 2014 at 12:14Somebody knows where to get the ILI9341 driver for 4 wire 8bit data interface? Driver must build for stm32f429zi.
jo by Associate II
  • 886 Views
take care: inverted DEPolarity at LTDC!!
Posted on December 26, 2014 at 13:07In LTDC_GCR register of LTDC at STM32F429   HSYNC, VSYNC and DE signal polarity may be chosen:Bit 31 HSPOL: Horizontal Synchronization Polarity This bit is set and cleared by software. 0: Horizontal Synchronizatio...
STM32 RTC problem
Posted on December 26, 2014 at 08:39Hello,I use an STM32F407 microcontroller for my project that i use RTC on it. The RTC is clocked from LSE. It works normally when the power is on. But when i switch off and on the device, the RTC falls behind the ...
omeryaman by Associate II
  • 2313 Views
STM32F4 Discovery - can't flash-program device
Posted on December 17, 2014 at 08:31(Note: I'm experienced with flash-programming microcontrollers from other vendors, but this is my first go with STM)I have a STM32F4 Discovery board (with a STM32F407VGT6 fitted).I use GCC-4.8.3 with OpenOCD-0.9.0...
pacman by Associate III
  • 8775 Views
  • 16 replies
