SDRAM and unaligned memcpy causes exception
Posted on August 13, 2015 at 00:29I am using the The STM32F7 discovery kit (32F746GDISCOVERY) kit and I have run into an issue with memcpy using IAR (which seems to do some clever internal aligning and then copying 4 byte words).In short, the copy f...
wilfred by Associate
  • 1815 Views
Stm32 Nucleo L152RE and low power configuration
Posted on July 30, 2015 at 16:36Hi to all, i use stm CubeMX with HAL library and Keil now i want develop  the low power configuration on my Nucleo  stm32L152RE, can you see a example or other information? can you help me? best regards A.
antonio23 by Associate II
  • 1125 Views
IBIS Model understanding
Posted on August 13, 2015 at 12:48Hello everyone!I am currently working on a PCB on Altium Designer 15 and I am trying to do some tests on signal integrity but the proper driver on I/Os must be chosen.I already have the IBIS model ''stm32f427_437_42...
How frequency and powerconsumption are related
Posted on August 13, 2015 at 04:54What I'm about to ask is somethig generic and basic So everywhere it can be found that for going to low power mode reduce the clock frequency, How reducing clock frequency reduces power consumption ? #low-power #...
CubeMX ADC sampling time
Posted on August 12, 2015 at 19:30I use CubeMX to generate code.How can ADC Sampling Time?CubeMX does not give option for that and always generate:SamplingTime = ADC_SAMPLETIME_3CYCLES;My problem is if I changed it manually (to for example 28 cycles...
smhhadima by Associate II
  • 1357 Views
IAP Ethernet(web server) issue on STM32cubef4
Posted on August 13, 2015 at 08:18Hi all,I am testing on IAP Ethernet(web server) functionality but I can't download my application.Here is my test environment- STM32f429 Eval board- STM32cube4 1.7.0- Eclipse + GCC, IARAnd here is my story,I program...
mclapd by Associate II
  • 829 Views
STM32F401RB SDIO
Posted on August 05, 2015 at 20:37Hi all, there is something wrong with my project's microSD card part. I have done it on the  STM32F407 discovery board and it worked perfectly the data was succesfuly written to the microSD card. But for the end pro...
matas by Associate II
  • 4329 Views
  • 13 replies
STM32F446 DMA Mem to GPIO
Posted on August 12, 2015 at 02:12 I have the example from the library showing DMA (mem to mem) working with the following initialization: /* Configure DMA Stream */ DMA_InitStructure.DMA_Channel = DMA_CHANNEL; DMA_InitStructure.DMA_...
daniel2 by Associate II
  • 6174 Views
  • 14 replies
STM32-MP3NL/DEC Audio Engine MP3 Decoder and Utilities ?
Posted on August 12, 2015 at 23:49Hi Guys, I read about STM32-MP3NL/DECAudio Engine MP3 Decoder and Utilities in this link : http://www.st.com/web/en/catalog/tools/PF250969 Where can I find the software ? Is it not free ? Or I need an external chip ...
Basic questions about Alternate Functions
Posted on August 12, 2015 at 10:38Hi all,I am a beginner of MCU, and right now is digging into STM32F1xx serial MCU, which is pretty old, but simple enough for beginner. I have spent a lot of time on some example codes, still with the confusion that...
laojian by Associate II
  • 5552 Views
