HardFault at ORR instruction, what is happening?!?
Posted on June 02, 2016 at 00:28Hi,I am trying to get STM32CubeMX + arm-gcc + Nucleo-073RZ to do things. It won't.I can see in my debugger and lst file that08000990 <SystemInit>:SystemInit():/Users/dongfang/workspace-arm/stm32cube-playground/Nucleo0...
soren by Associate II
  • 1246 Views
STM32F100C8T6B (Rev. Z) problem
Posted on June 01, 2016 at 16:35Hi all. I can't get more far than reset handler. On a first instruction I'm failing into HardFault_Handler. SCB->CFSR says  STKERR and IMPRECISERR.I see it only in STM32F100C8T6B. They all have rev. Z. All another chi...
STM32+HAL+SPI
Posted on June 01, 2016 at 17:01HiI'm trying to communicate with ADC through SPI interface with HAL layer and ended up with issues.At start I configure adc:HAL_SPI_Transmit(&hspi1, &SDATAC, 1, 3); //0x16HAL_GPIO_WritePin(GPIOC, START_Pin, GPIO_PIN_S...
STM32F429 USB Audio 16/24bit
Posted on March 21, 2016 at 07:51Hi, I want to ask you if it is possible using HAL to change usb format audio from 16bit to 24bit and vice versa. Now I can choose in windows between different frequencies of 16bit sampling, but if I change usb descri...
STM32F042 PVR/Brownout Setting
Posted on May 10, 2016 at 12:47 I am having an issue with a slow supply ramp, so I have been trying to set theSTM32F042 to do a software reset if the supply is under say 2.5Volts. I've been playing around with the PVD settings, and interrupts to...
rob2399 by Associate II
  • 1023 Views
How to use the stm32f4xx ADC in dual regular simultaneous mode
Posted on May 31, 2016 at 16:38The task is to measure three phase power. ADC1 measures voltage, ADC2 measures current. Here is the adc configuration routine:static void ADC_Config(void){  ADC_InitTypeDef       ADC_InitStructure;  ADC_CommonInitTypeD...
zdravko by Associate II
  • 2041 Views
[STM32L4] I2C HAL read register problem
Posted on May 31, 2016 at 08:32 Hi, I'm trying to read register in my accelerometer FXOS8700. I'm using code below on STM32L476: uint8_t FXOS8700_ReadReg(uint8_t reg) { uint8_t value=0; HAL_I2C_Master_Transmit(&hi2c1, FXOS8700CQ_SLA...
zenobik by Associate II
  • 971 Views
STM32F407 Watch dog
Posted on May 25, 2016 at 10:23Hi, I enabled WDT in STM32F407 controller and I have a very tight loop which is resetting the flag. Here is the code     RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG, ENABLE);     WWDG_SetPrescaler(WWDG_Prescaler_8);    ...
nps by Associate II
  • 2409 Views
