STM32F103 USART2 CAN'T SEND DATA
Posted on August 08, 2016 at 08:42Hi all,I've built USART2 connection with using none-flow-control via rs485 through my pc. Sending data from my pc to stm32f103 is working correctly however, i can't send any data from stm32 to my pc.Do you have any ...
STM32F103RET High speed communication with SDcard!!!
Posted on August 12, 2016 at 14:26Hi I want to know if I can reach a writting speed of 3-4Mbytes/sec to MicroSD ?Microcontroller is STM32F103RET.Clock rate: 72MHz.MicroSD 2-4G calss 10.SDIO protocol.If you have any same experience , please to help m...
eleman3 by Associate
  • 879 Views
STM32Cube: STM32F334 HRTIM configuration for external pins
Posted on August 12, 2016 at 10:48Hi, I was trying to configure HRTIM of STM32F334C8T of my STM32F3348DISCOVERY board with STM32Cube and encountered an issue. I set External Event 6 as: - Source : External Pin (source 1) - Polarity : high - Sensitiv...
tgadeyne by Associate
  • 1329 Views
SPI communication two MCUs - bitshift
Posted on August 12, 2016 at 12:12Hi, I want to transmit and receive data between two STM32F401RE NUCLEO boards. Performance does not matter, so the simplest approach seems to be using the blocking HAL_SPI_TransmitReceive(..) function on both sides....
janisheil by Associate II
  • 1213 Views
Bug Repport: CubeMX 4.16.0 DMA ''Use FIFO'' Checkbox stuck
Posted on August 10, 2016 at 23:11Using CubeMX version 4.16.0 with DMA it does not let you turn off FIFO mode. The check mark does not deselect. The generated source code needs to be manually modified to turn off FIFO. After the following change the...
ayarema by Associate II
  • 2506 Views
STM32F4 HS USB incomplete isochronous OUT interrupts
Posted on October 03, 2014 at 01:12Hello! I`m use STM32_USB-Host-Device_Lib_V2.1.0 and try to run the USB audio device on STM32F407VE + USB3300, the device is properly detected and any audio player starts playing, but the data did not come as soon a...
