STM32F103x8 interupt not working after relocate
Posted on November 16, 2016 at 02:56 I have problem after relocating, my interrupt stop working. A brief explanation about my firmware i) the bootloader (0x08000000) ii) the main application (0x08004000) In my bootloader, I r...
ho by Associate II
  • 1161 Views
Datasheets of STM32L053K8U6
Posted on November 02, 2016 at 11:23I recently got STM32L053K8U6 from Arrow Electronics. I am very surprised as I couldn't find the datasheets/technical documentation of STM32L053K8U6 . I believe STM32L0 series MCUs have 10 years longvity commitment...
krish by Associate II
  • 3950 Views
  • 14 replies
Low level drivers and Cube
Posted on August 02, 2016 at 15:02I'm working on a project with the stm32l432 which really requires a minimalist approach with respect to code.   I like cube for pin assignments, and configuration, but it doesn't appear there's a way to generate the...
STM32F030 UART HalfDuplex config
Posted on November 15, 2016 at 23:07 Hello there, I am trying to configure uart in half duplex mode on STM32F030 device (usage with RS485 later on). I am having difficulties in making the program work properly using the HAL library. This is ...
stm32f303xx pma address calculation conflict
Posted on November 09, 2016 at 18:49HelloAs i inspected through stm32cubef3_1.6 and tested with keil uvision, pma address caculation is as follows:USB_ADDRn_TX: 0x40006000(usb PMA base) + (BTABLE + 8*n) * 2USB_COUNTn_TX: 0x40006000(usb PMA base) + (...
VCP RS485 mode
Posted on December 16, 2015 at 10:48I am trying to make a USB-Serial converter. I need some help about communication via RS485. Device Manager properties of a serial converter different brand shows RS485 checkbox and works fine. But STM32 VCP doesn'...
Bit RFWRA in register MACDBGR is never set!!!!!!
Posted on November 15, 2016 at 05:56Hi!I have LAN8720, STM32F4DISCOVERY, CP2102I connected PC-LAN8720, LAN8720-STM32F4DISC, STM32F4DISC-CP2102, CP2102-PC.I wrote such program for STM32F407://Ethernet/*************************************************...
