STM32F4-Discovery EEPROM emulation demo does not work
Posted on December 07, 2016 at 03:21I have STM32F4-Discovery board. (MB997B with Discovery-MO expansion board)From STM32Cube package, I ran several examples, applications and demo successfully. But EEPROM_Emulation application does not work well.STM...
hansuk by Associate
  • 2032 Views
LQFP144 pinout overlap
Posted on December 10, 2016 at 20:57So it happens that i have an overlaping pins if I try to connect an sdram 16Mx16bit an an 24bid RGB LCD. Will there be any major complication if I connect overlaping LCD bit to ground? Do i have to cange software ...
luchiann by Associate
  • 1104 Views
STM32F030K6T6 support touch library?
Posted on December 12, 2016 at 12:00hiin this doc en.DM00210526.pdf there is no name of STM32F030K6T6 to know which pin is which Chanel of touch.and in STM32F030K6T6.pdf there is no name of touch in pin configuration.can i use touch library on this ...
How to Turn off all clock of STM32L0xx ?
Posted on December 12, 2016 at 14:43Hello,I am using STM32L0xx MCU in stop mode. but can able to achieve low power as given in datasheet?Please help me to turn off clock and also i want suggestion to achieve it.Thank you in advance. #turn-off-all-cl...
RTC Misbehavior and strange display
Posted on December 13, 2016 at 15:36Hi, I'm working with STM32L486RG ultra low power microcontroller using the IAR v7.4 IDE.I'm using the RTC peripheral in order to get the real time clock . My clock source is an LSE crystal which has 32768Hz as fre...
0690X00000603HzQAI.jpg 0690X00000603VGQAY.jpg 0690X00000603VBQAY.jpg 0690X00000603L0QAI.jpg
I2C Timeout waiting for TXIS flag
Posted on December 12, 2016 at 17:26ST Community,I have been trying to get I2C communication working on my STM32L073RZ Nucleo board for some time now, but to no avail. After doing a bit of stepping through the code, it looks as though a HAL_TIMEOUT ...
conner by Associate II
  • 7160 Views
