Setting up my STM32L031 for PWM input using TIM2
Posted on August 30, 2017 at 03:38Hi Folks,I think I've set up my TIM2 correctly using the CUBEMX but I'm new to the STM32 world and I'd like someone to take a look at this.  I'm going to be reading the output from a optocoupler connected to the 120...
STM32F303k8 DMA Underrun on channel3 to DAC
Posted on August 30, 2017 at 06:19I'm using a http://www.st.com/en/evaluation-tools/nucleo-f303k8.html board, and trying to get a LL dac example running that was targeting the STM32F334R8-Nucleo board that was provided in the STM32Cube_FW_F3_V1.9.0....
Hard Fault Exception using STemWin & STM32F446ZE
Posted on August 30, 2017 at 05:28Hi all,      I am getting hardfault exception in my code. And when i watched my registers CFSR and HFSR their values are like        CFSR = 0x00001000             - IBUSERR = 1             - STKERR = 0        HFSR  ...
Luke Lee by Associate
  • 1175 Views
I want to use pwm input capture TIM3 CH1/CH2.
Posted on August 28, 2017 at 10:52Dear All,I want to use pwm input capture GPIOA.6 and GPIOA.7 using TIM3 on STM32F407IG(176pin)Channel 1 and Channel 2 work's fine if I set just one of them.But channel 1 and channel 2 does not work if I set at the s...
can protocol demo stm32
Posted on August 29, 2017 at 11:15HiI need to setup a can protocol demo where I send and receive CAN 1-2 simple CAN msgs. What is the cheapest HW to buy? What isw the quickest way to go? It has to be a STM32. Can I use 2 STM324xG_EVAL boards?STM324x...
Resolved! Does STM32F429I-DISCO KIT support ARM ULINK2 Emulator?
Posted on August 29, 2017 at 15:11HiNow I'm trying to buy http://www.st.com/en/evaluation-tools/32f429idiscovery.htmlBut I want to make sure before to buy http://www.st.com/en/evaluation-tools/32f429idiscovery.htmlDoes STM32F429I-DISCO KIT support h...
Stm32f302 interface to Adxl345
Posted on August 29, 2017 at 22:02Hello everyone I am trying to interface acceleration sensor Adxl345 to stm32f302 through I2C  using the HAL Library. Actually I am learning the programming , does any one help me how to get the data from sensor. I w...
Bunty Gtm by Associate II
  • 1309 Views
I2S <>QSPI Flash via DMA
Posted on August 29, 2017 at 17:26Hi Guys,I'm struggeling with the I2S where the Datasource is an QSPI Flash (2 Datalines) on a STM32F446. How can I set on the right way the pointer to the Flash in the Function HAL_I2S_Transmit_DMA() for the DMA Tra...
