STM32F4 USB to PC communication
Posted on December 31, 2017 at 10:35Hi,I am using STM32F405 mcu.now i want to interface my STM32F405 usb with PC  win32 & win64 bit os.I dont want to use any converter IC for same.Thank you.
STM32 with integrated phy
Posted on September 25, 2015 at 12:28Hey, is there an STM32 device which would have an integrated phy and would only require an RJ45 jack for LAN interface? I tried to look for it, but I could not find it.
matas by Associate II
  • 2842 Views
STM32L432 - HSI16 accurate enough for use without crystal?
Posted on December 30, 2017 at 16:23I started designing a product with a STM32L432KCU6. Looking at the datasheet I noticed that the HSI16 clock seems to be very accurate. From Figure 14, p 95, it seems that the clock is pretty much within 16MHz +/- ...
mluessi by Associate II
  • 2022 Views
SPI receive data from external ADC on STM32F4
Posted on December 29, 2017 at 22:50Hello,i am working on a design which uses a stm32f427 device, and 3 external adc chips.The ADC chips have 3 pins, SDO, SCK and CS.The SDO,SCK wil be shared from the STM32F4 with all 3 chips,  the 3 chip select sig...
Bogdan by Senior
  • 890 Views
Digital pin status read on STM32f103C8T6
Posted on December 29, 2017 at 20:43Dear community,I just started to learn stm32 trying to forgive about AVR.The problem I faced with is I can not force my STM32F103C8T6 to read pin PB0. I`ve read both Datasheet and RM0008, I saw the examples of ano...
HAL_CAN_Transmit timeout error
Posted on November 14, 2015 at 11:22 Hello, I'm trying to communicate with a STM32f4x9 EVAL board and a STM32F429-Discovery board via CAN Bus, I am using MCP2551 transceiver IC for Discovery board, I know that CAN1 is being used by LCD an...
Running Code from SRAM
Posted on September 02, 2014 at 23:13Hi:I am using STM3221G-EVAL board. The board has a couple of switches to select the Boot source.Boot related jumpersBOOT 0                 BOOT 1                 Boot source    0                          1 or 0  ...
eduardo2 by Associate II
  • 2898 Views
