STM32L073RZ-Nucleo stop mode
Posted on November 28, 2017 at 06:54I tried STM32L073RZ-Nucleo. and use 'en.stm32cubel0\STM32Cube_FW_L0_V1.10.0\Projects\STM32L073RZ-Nucleo\Examples\PWR\PWR_STOP_RTCâ€�  but I got a strange question:  first time enter stop mode ,current is 1.2uA ,RT...
guo sir by Associate II
  • 1293 Views
Error Trying to Implement a Project on another Project
Posted on March 15, 2018 at 20:32Hello there,I'm using the IAR to code my project for STM32F091VC to collect weather data from 9 sensors. Recently I changed the Wind Direction sensor that was at first digital and now is analogic. The problem is that...
STM32H7x3 datasheet and Flash memory programming
Posted on March 13, 2018 at 23:04Hello,DS12110 rev. 3 in table 51 .' Flash memory programming (single bank configuration nDBANK=1)' misses values for sector erase time with parallelisme x32 and misses even an entry for parallesim x64.
SPI Not Sending
Posted on March 16, 2018 at 12:10Hi  I am still learning on the STM32, and currently working on the Nucleo-64 (STM32L073RZT6) board. I am currently trying to get the SPI to work, I am simply trying to send a byte out so I can capture it on my logic ...
USBD_CDC_Init BUG ?
Posted on March 16, 2018 at 15:41Hi, i generated a little project with STMCUBE (Version 4.25.0 and packages 1.21.0)  for STM32F415 with FreeRTOS  and only CDC inteface, but not work.During the INIT on comand 'Set configuration = 1' i receive a error...
Marco1 by Associate II
  • 783 Views
Duplicated code in stm32l0xx_hal_pcd.c V1.8.0
Posted on January 22, 2017 at 00:58Hello,I just started a mini project using USB CDC with STM32CubeMX and while trying to figure out how to use CDC driver i found this piece of code.I think there is code duplication (copy-paste) in STM32Cube_FW_L0_V...
STM32F103C8t - CAN problem
Posted on March 15, 2018 at 22:24Hello guys!I am new in using CAN interface, and for the first time, I started to use it in my project. I used STM32F103C8t. When I wanted to use CAN interface, there only happens time-out exception in run-time and I ...
abbas by Associate II
  • 2988 Views
Temperature Problem with STM32F429 BGA Board
Posted on March 15, 2018 at 16:06Hello,we have some temperature problems with STM32F429 (BGA) controller boards. If the temp. exceeds by some boards 40°C, and other boards at 60°C the internal voltage regulator shut down, measured at VCap1 & 2. Ev...
Marc T by Associate II
  • 2960 Views
