CubeF0 1.9.0 ceases Atollic support. Why?
Posted on September 27, 2017 at 09:54Hi !Does anybody know the reason for:Projects:Remove support of Atollic TrueSTUDIO STM32 (TrueSTUDIO) toolchain.Are all Cube versions affected?Best regards,HaJo
hjs by Associate II
  • 2923 Views
Resolved! USB device mode, low speed
Posted on June 24, 2018 at 14:07Can the USB controller of STM32F072 work in LOW speed mode?A. Is it possible to enforce low speed mode against a host capable of FS and HS?B. If a host is low speed only, will the USB controller work with it? I've tri...
Pavel A. by Super User
  • 3281 Views
Resolved! STM32L4 LSI and power-down sequance
Posted on January 14, 2018 at 09:25Hello,In our Evaluation board of the STM32L486QG we encounter in strange behavior of the MCU.When the power supply turned off and on quickly we saw that sometimes the MCU start to getting in to loops of IWDG.We are...
shachar y by Associate II
  • 2300 Views
SPSGRF-868 Throughput
Posted on June 25, 2018 at 11:08Hi,Can someone help if it was possible to get 200kpbs+ throughput between SPSGRF-868. I would highly appreciate, if someone can share their experience. My distance would be not more than 10-12mts between transceivers....
Resolved! data from ADC104S021 via SPI seems not correct
Posted on June 19, 2018 at 07:47 Hi All, I am developing driver for ADC104S021 for STM32F103 I have tried to read AD converted value from ADC via SPI, the value seemed not correct one. timing diagram as follows (from datasheet). m...
Annotation/development/ note
Posted on June 25, 2018 at 06:12Hello, I have microcontroller stm32 f103, maybe you can give me annotation note or other recomendation for programming realtime system for exampla - electrodrive?#annotation #realtime #note #help #stm32 #f103
decoding hex file for stm32101c8 cpu
Posted on June 24, 2018 at 10:53I have a program for a board we use that outputs a PWM signal.I did not program the board but we have the HEX files for JTAG to the board.Can this file be decoded back to source code?
