STM32F407VG UART DMA Not Working Properly
Hello Guys;I am trying to do Push Button Interrput UART+DMA application, but I have a problem about the UART DMA. When I configure the dma in normal mode it just make transmit once. I need to use dma every time I push the button. This is my code ;#i...
STM32L5
https://www.st.com/en/microcontrollers/stm32l5-series.htmlMarketing status is Preview and Proposal.JW
Resolved! General questions on timers.
Hello,I'm still learning how to handle timers in CubeMx. I've got some simple questions.I'm using TIM1 and TIM2 of the L432KC. In the clock tree, I see APB1/APB2 peripheral and timer clocks bus frequencies. I thought that when I set a prescaler, the ...
xpp07 by Senior
  • 7506 Views
  • 12 replies
How to fade PWM without Delay?
I have L432KC nucleo. I’ve set Timer 1 for PWM generation. I’m controlling the duty cycle via the CCR register. When increasing o decreasing the duty cycle, I want it to be slow. It works with a for loop and delay. But HAL_Delay prevents from doing a...
xpp07 by Senior
  • 3183 Views
stm32l073x Errata/flash configuration issue
i have been working in these days with stm32l073x.I want to run MCU with stop mode.But i have a doubt about reading the errata.How can i interpret correctly the following conditions in the errata datasheet?does the issue occur when two conditions r...
I fixed my Internet issues on this website.
If you have issues with this site, then you have to Clear the Browser Cookies Cache.in FireFox,3Bars for optionsoptionssearch for cookiesclear cookie cache button top left.You have to logout of ST.com and login again... and fixed...
T J by Lead
  • 2137 Views
