Reading different CPUID when ever STM32F107 is power cycled.
Hi ST community,I am trying to read the CPUID of STM32F107 using the following code snippet. But the problem is each time I power cycle it, I am reading a different CPUID. I am reading CPUID from address location UID_BASE_ADDRESS(0x1FFFF7E8) for STM3...
Skira.17 by Associate II
  • 1149 Views
Resolved! Clocks Initialization wrong (SOLVED).
Hi all!,I'm, triyng to program using CMSIS in order to learn how registers works.If I use the SystemClock_Config() generated by STM32CubeIDE all works properly, but if I use my own rutine, the TFT wired to SPI3 dont show the fonts properly (I think i...
JAlca by Senior
  • 1647 Views
STM32H743XI Multi SPI Circular DMA with GPIO manipulation
Hi, I want to achieve the title's behaviour to communicate with multiple SPI sensors in the 5 SPI buses at the highest possible throughput and minimal CPU load. I first tried the following with 1 bus.void cpltCB(void); uint8_t RXBUFF[8];   void main(...
CMA by Associate II
  • 4092 Views
About using uart in interrupt mode
HiWhen I configure uart in interrupt mode, can I use it in polling mode in the future? (For any reason)my other question, when is the HAL_UART_RxCpltCallback function called, is it when all data is received ? or when byte by byte is received?Thank yo...
xmart by Associate II
  • 1896 Views
