dual core data share
HI I'm working on STM32H745. I'm tiring to understand share data with 2 cores. Can you please post a program ?
TWalp.1 by Associate II
  • 1209 Views
TIM1_BKIN Behavior When Fault is Detected
Please I want to Know how TIM1_BKIN for example in STM32F103C8T6, behavior when it detects fault and when the Fault disappears? What is the approximate Time it may take to turn off the TIM1 PWMs Channels ant when the fault disappears, does it delay ...
Resolved! Write & Read to SDRAM with STM32H743
Hello, I want to write and read from an external SDRAM using an STM32H743. I never did this project before and I did not find any example of project to help me.Please can you point me to good example of project "SDRAM/FileSystem" ?Thank you.
PyKe by Associate III
  • 8442 Views
STM32 Functional Block Programming
Hi,Is there any functional block diagram programming for STM32 microcontrollers? The logical operation, input management, arithmetic operations, decision controls, etc.Regards,Umit
umtkyck by Associate II
  • 3192 Views
STM32L4 only does debug session only every other time.
I have a problem when debugging STM32L4 form CubeIDE with STLINKV2, the debugger only starts every other time. First start of debug session is ok, program halts at "main()". When debug session is closed and started again, the download is successful, ...
How does watermark for FDCAN work? - STM32H7
Thats a question that has bothered me for a while. When receiving FDCAN messages, I can specify a watermark on how many bytes the interrupt triggers.How exactly does it work?If I have a message of 8 bytes and I set the watermark to 1 byte, does the i...
Yoschii97 by Associate III
  • 1764 Views
Timer synchronization offset STM32G431RB
I am trying to configure two timers (TIM3 & TIM4) to start at the same time, following the procedure in RM0440 pg. 1304. However, when I scope the output pins of my timers, there is a ~25us delay between the edges of the pulses. Is there any way to e...
IBeck.1 by Associate
  • 2476 Views
