Resolved! In my I2C Slave program the Callbacks are not being called.
I am using HAL_I2C_Slave_Receive_DMA() function and am putting flags in each of the Callbacks which I have redefined in my code from the weak ones in stm32g0xx_hal_i2c.c. I have also tried putting breakpoints in the callback functions to see if it fo...
KiptonM by Lead
  • 13661 Views
  • 11 replies
Release Version Control?
Hi,I'm pretty new to the st and embedded world.I'd like to know what is the recommended way/how do you version control your releases?I'm looking for something better than manually writing the release version in as a const parameter in a configuration...
BBlad.1 by Associate II
  • 1465 Views
When I used HAL_ADC_Start_DMA Timer Pwm does not work
I am working with stm32f407vg disc. I have to read couples adc same time, one of the sensors is should be control a servo motor. Without this hal function HAL_ADC_Start_DMA servo works clearly. when i activate this function servo doesnt work.
Bugrahan by Associate
  • 1643 Views
BPfei.1 by Associate II
  • 2967 Views
