Resolved! Has ChatGPT bricked my NUCLEO-L433RC-P board :(
I wanted to do a full chip erase using STM32Programmer (I am trying to debug a custom bootloader) but kept getting the error "Mass erase operation failed.  Please verify flash protection".I sent the following option byte screenshot to ChatGPT....Chat...
STM32F446RET6 Timer and clock
Hi,  I designed the us and ms delay functions using timer 2 and 4. Initially in the PLL source, I was using HSI, but it had some errors, so I switched it to HSE. I was using my delay function to control the DAC output, but when I switched to HSE, all...
Junzhe_0-1758900040115.png Junzhe_1-1758900047568.jpg Junzhe_2-1758900122851.png Junzhe_4-1758900460320.png
Junzhe by Associate II
  • 542 Views
Resolved! NOR Flash on OSPI bus with ST MX25UM51245G Library
Hello, I am struggling to use the following ST library for a project I am working on, I am using an stm32u5 with an MX25UM51245G NOR chip connected to the OSPI1 bus.  The library provided is setup to use XSPI_HandleTypeDef, Can this library be used w...
brohr01 by Associate III
  • 687 Views
Resolved! STM32F4 marking
标准时间(标准时间)的标签产地和芯片产地不一样,请问这个是否正常 Translation: The label on this device (Standard Time Clock) indicates different countries of origin for the product and the chip. Is this normal? Edited by ST moderator. In next time please use English as this is an i...
xuzejian by Associate II
  • 3509 Views
