TIM_DMAError with ErrorCode 1
Hi, I am trying to send WS2812 LED data as PWM signal using DMA. All works on STM32F091/STM32F103, but when I try to do it on STM32F407 sending via DMA fails.My TIM1/DMA/NVIC settings: I am trying to call:HAL_TIM_PWM_Start_DMA(&htim1, TIM_CHANNEL_1, ...
JBond.1 by Senior II
  • 1587 Views
memcpy vs split SPI transfer
Hello,I came across this question while writing a driver and I would like to ask what is your best practice in this regard. So lets say you want to interface with an chip via SPI. To perform any action, a command byte or a sequence of commands is req...
MLang.7 by Associate III
  • 1747 Views
STM32F779AIY6 - What if NC pins are connected to GND?
Hello,i just received some custom boards with a STM32F779AIY6 on it.3V3 net and GND net have a short circuit when MCU is soldered, without MCU there is no short circuit.I checked everything, it should be fine.But what i just found was that the datash...
Why is my ADC reading zero for values?
My objective is to utilize ADC peripheral for reading analog signals and converting them to digital. I am using the polling method for reading ADC values. When setting up the chip configuration, I am currently using the Nucleo-H743ZI with default set...
0693W00000FCaDFQA1.png 0693W00000FCaDtQAL.png 0693W00000FCYf3QAH.png 0693W00000FCaJSQA1.png
LRive.1 by Associate
  • 5709 Views
Variable NOR flash wait-states using the STM32F4's FSMC
Hi all,I'm planning to use an STM32F405 and its FSMC to interface with an external, parallel 16-bit NOR flash chip from Infineon/Cypress.This chip has a read page size of 32 bytes / 16 half-words.When reading a half-word that is located in a page whi...
DashNode by Associate
  • 1167 Views
