Resolved! QSPI nCS behavior on STM32H747
Hello,I am facing an issue with nCS pin of QSPI on STM32H747BIT.Reference manual indicates that SCLK is supposed to wait one period after nCS fall before starting operations :But I do not observe this wait on my board.*Yellow is the clock *Blue is th...
BBute.1 by Associate II
  • 2459 Views
Resolved! C question on pointers???
Hello all....Ok....not sure what i am missing here but this fails miserably....The compiler hates when I try and assign test = The return function works fine, I have made the return variable static so as not to lose the scope....test is an array so I...
SWenn.1 by Senior III
  • 4902 Views
  • 11 replies
Transition from PIC
Hello AllNoob question here - seeking advice.I've been using PICs for many years now and writing only in assembler. I've reached the end of my tether with microchip and the lottery of which IDE will work with which programming tool and with which dev...
AThor.2 by Associate II
  • 5631 Views
  • 12 replies
PWM divider not working
I try to divide pwm like that TIM_InitStruct.TIM_ClockDivision = TIM_CKD_DIV1;it is not working. I am using stm32f030 TIM_TimeBaseInitTypeDef TIM_InitStruct; TIM_OCInitTypeDef TIM_OCInitStruct; // OC: Output Channel RCC_APB2PeriphClockCmd(RCC_APB2Pe...
hazall by Associate III
  • 747 Views
Resolved! "Load project image" for STM32F7508-DK
Hi. I'm running through the STM32 starting tutorial and I am at a piece of code that configures GPIO pins. One of the instructions on the readme is this:In order to load the ExtMem_Boot code : - Open your preferred toolchain :- Open the Project - Reb...
OIp.1 by Associate III
  • 1494 Views
