bank swapping in stm32h745
Hi, I want to use OTA in stm32h743, for that I need to switch between two bank after flash write, as per reference manual//HAL_FLASH_OB_Lock(); HAL_FLASH_OB_Unlock();   /* Set OPTSTRT Bit */ SET_BIT(FLASH->OPTSR_PRG, FLASH_OPTCR_SWAP_BANK); /* Wa...
ykn by Senior
  • 2732 Views
Calibration issue on STM32H750 - DIV256 versus DIV1
The calibration at a DIV256 works most of the time but some MCU must be calibrated with a DIV1 otherwhise I get an offset of zero. We use VREFBUFF as reference. We try to swap an MCU with good result (DIV256 worked). One MCU calibrated but with error...
guys_fr by Associate II
  • 1797 Views
Resolved! Problem with Flash write STM32G474RE
Dear colleagues,I woild like to ask you help me with may issue below:Why do I lose data when writing flash memory and an error occurs my code in the attachment.Code seems good, but I am sure that I loose something.In memory loosed letters "llo" from ...
IPast.1 by Associate II
  • 5608 Views
Resolved! STM32驱动EC11编�?器
使用STM32F446RE的Tim encode模�?接�?�EC11编�?器数�?��?�以区分正�??转�?�?如何使用LL库实现?
YLi.13 by Associate II
  • 2627 Views
