How can I disable a I2S module ?
I am using cube mx for my design and I have some peripherals (ADC, Timer, I2S2, I2S3). I am making streaming by usb of some of them. I want to stoop i2s modules when i am not using it becouse affect to other modules sampling rate.By default Cubemx m...
tcg by Associate III
  • 4153 Views
How to implement PLL in STM32?
I am trying to implement a Phase Locked Loop in a microcontroller STM32. I have a reference signal and feedback signal which has $\phi$ difference wrt reference signal. For the moment, I am not using a real time feedback signal, rather simulating it ...
RShre.2 by Associate III
  • 9837 Views
Glitch value for DAC in the STM32G071
Hello.I can't find Glitch value for DAC in the STM32G071 documentation, and also what type of DAC is implemented in the MCU: R2R, resistor string, etc.Where can I find the information I need?
Akoli.2 by Associate III
  • 3158 Views
STEPPER MOTOR using I2C
Hi, I have a problem with starting a stepper motor using the I2C bus. It uses the NUCLEO-F746ZG microprocessor, the SMC 64-BP stepper motor driver and the KH1634-03CA stepper motor. The main problem is finding the address of the controller and giving...
PBiał.1 by Associate II
  • 3979 Views
How to reduce the consumption of the Nucleo-L073RZ board to less than 700uA? How to disable J-Link part on the board?
I am developing a card with a supercap storage, I designed it for a consumption of 40uA as it is written in the datasheet, however I reach only 3mA and I use the "standby" mode written and found on the internet. Can you explain me how to disable the ...
Thomcheh by Associate
  • 2018 Views
Resolved! Hi..I am using STM32U575 NUCLEO ..there are three drive levels are mentioned for LSE...which one one should be used or which is more suitable for low power consumption and I need to know the power consumption in each case (numerical value)..
In the errata sheet,it is mentioned that low drive mode and medium low drive are not working.. but I checked and they work fine...is there any correction in the errata sheet...?..Can I go with low drive mode for LSE (NUCLEO-U575ZQ)???
ABDUL1 by Associate II
  • 4386 Views
