Resolved! How to transmit five byte data transmit in UART_DMA?
I already try for send five byte data in UART DMA. I am using the controller in STM32G030K6T6. Data transmition is working properly but output is did not taken properly. The problem was am transmit data five bytes for UART_DMA but DMA transmit only t...
_legacyfs_online_stmicro_images_0693W00000bVgJtQAK.png _legacyfs_online_stmicro_images_0693W00000bVgJjQAK.png
mrsmile by Associate III
  • 9184 Views
  • 21 replies
Firmware does not work if not debugging
Hello, i would like to post a problem that i have: i have a custom STM32H755BI (dual core) board that i usually flash with CubeIDE and i debug. Unortunatelly i noticed that the board works fine, but if i reboot the board and i connect with a j-link s...
halbeeee by Associate II
  • 1567 Views
Can't receive any CAN data on STM32F303CCT6
Hello I tried to receive any CAN signal on my device based on STM32F303CCT6. Maybe you have solution :), CAN pins are remapped on PB9 and PB8 pins by STMCubeMX configuratorBelow my code (main.c): https://pastecode.io/s/7av2ge6mand my settings in con...
_legacyfs_online_stmicro_images_0693W00000dDdRcQAK.png _legacyfs_online_stmicro_images_0693W00000dDdRhQAK.png _legacyfs_online_stmicro_images_0693W00000dDdRmQAK.png
MSzła.1 by Associate III
  • 1132 Views
Resolved! STM32F302VCT6 - PC13 -> RTC_OUT_CALIB ?
I would like to set a 1Hz signal on the PC13 (RTC_OUT_CALIB). I have found a manual in document AN3371 (see picture in appendix). The code is also in the appendix. Unfortunately, nothing happens on the PC13 but the RTC works. If anyone has any idea w...
_legacyfs_online_stmicro_images_0693W00000dDc1sQAC.png _legacyfs_online_stmicro_images_0693W00000dDbR2QAK.png
KHabe.1 by Associate II
  • 3577 Views
