Resolved! Product life
Hello, We are looking for Controllers for our us based client. I want to know Product life and active years from this family of STM32(STM32F0 Series, STM32F4 Series, STM32F7 Series).  Can Someone help to find where i will get this info.it should be g...
Gajanan by Associate II
  • 2848 Views
ILI9341 with stm32f4
hello im struggling to find how to get font on the lcd screen with some generated font c arrays i have found could anyone please explain how these font tables work and how to draw the characters on the lcd itself ive wrote a pretty basic driver that ...
Resolved! Execute code in CCM SRAM failure (IAR, STM32G474)
Hello,I wanted to put some complicated calculation into CCM SRAM in my STM32G474RE MCU. I basically followed instructions of AN4296, unfortunately I found an issue when programming the MCU.A few attaches as below:1. The link script2. The code change ...
YWang15_0-1698216341612.png YWang15_3-1698216549128.png YWang15_2-1698216444813.png YWang15_4-1698216581002.png
YWang.15 by Associate II
  • 5247 Views
STM32H755 | lwIP | Ping two boards together
Hello everyone,I open a new topic since my issue seems to be characterizing only my application.I have implemented what I consider a rather stable lwIP - ModbusTCP/IP on a proprietary application using STM32H755 microcontroller. As long as I work wit...
Zzaaack by Associate III
  • 7213 Views
  • 13 replies
  • 4 kudos
I can't make bare metal LPUART work in L496
Hello all, I've recently started experimenting with bare metal programming in L496, I made LED and push button I/Os working, interrupts etc, but I cannot figure out the exact steps to make LPUART1 work and I cannot find any references/examples of LPU...
henry_kay by Associate II
  • 2461 Views
Resolved! STM32C031 pin PF3
Hi, I was reading the document "DS13867 Rev 3" (datasheet for STM32C031x4/x6) (https://www.st.com/resource/en/datasheet/stm32c031c6.pdf), and while searching about pin PF3, I found this strange information saying that it is a "Supply" pin type. I've ...
Hagi by Associate II
  • 1707 Views
Resolved! Possible to route ETR to a TIM1 channel
I have a product using a STM32H745ZIT that has an input signal connected to TIM1 ETR and in the normal case, an edge on the ETR using slave mode trigger results in a one pulse pwm output a set time later driven on TIM1 CH1 and TIM1 CH2.  A new use ca...
GHolc.1 by Associate III
  • 2292 Views
