Performing OTA on STM32F103C8T6 using ESP
Hi,I am looking for some guidance on my project. It would be great if someone could help me out.I am trying to perform OTA on STM32F103C8T6 using ESP. The ESP and STM communicate over UART. Here the binary is downloaded by the ESP from a server and, ...
Partham by Associate
  • 2993 Views
I can`t to turn on a TA1 output in HRTIM.
Hello! I am trying to start HRTIM TIMA in PWM mode. Clock frequency of HRTIM is 140MHz. I use CubeMX 5.1.0 , chip is STM32F334R8T7. The configuration of the timer is following: set source is timer period event, reset source is timer compare 1 even...
Resolved! flashing stm32h563zi
Hi,I am trying to flash STM32H563ZI,  (NUCLEO-H563ZI) but I get hard fault errorI will flash to BANK2 that starting address 0x081000000MY CODE;HAL_FLASH_Unlock();erase.TypeErase = FLASH_TYPEERASE_SECTORS;erase.Banks = FLASH_BANK_2;erase.Sector = 0;er...
Recep by Associate II
  • 2082 Views
Resolved! BSP_QSPI_MemoryMappedMode Enable doesn't work with W25QXX
Hi,I am trying to do a memory map with this board W25QXX and it's not working. For some reason even on the original code we can see the function for BSP_QSPI_MemoryMappedMode have a comment (https://www.waveshare.com/wiki/W25QXX_DataFlash_Board). Any...
aabba.1 by Associate III
  • 2610 Views
STM32F302R8 an error occurs after burning the hex file
I always get an error after burning the hex file to STM32F302R8. The burning is completed through STM32 ST-LINK Utility. Below is the error log.16:05:15 : ST-LINK SN : 0664FF51557051486717444816:05:15 : V2J33M2516:05:15 : Connected via SWD.16:05:15 :...
bebejjk by Associate
  • 1565 Views
