2020-07-21 1:53 PM
Hi all,
I am designing a motor controller board based on the B-G431B-ESC1 board.
What are the requirements to be able to use the ST Motor Profiler on my custom board?
Let's make the assumption that I am using the same schematics (same parts as the B-G431B-ESC1 board) but different layout.
Is it sufficient to configure the board using the MotorControl Workbench 5.4.4 in order to be able to use the Motor Profiler?
Best,
Alessandro
2020-07-23 8:25 AM
Hello Alessandro,
About your first question:
About the second one:
Thanks and best ergards,
Claire
2020-07-23 8:25 AM
Hello Alessandro,
Claire
2020-07-23 6:44 PM
Thank you for your response.
Is it possible to change the shunt resistor value? Assuming that the pinout of my custom board is the same, what happens if I change the shunt resistor? Is it possible to tell the profiler that a different shunt has been used?
Best,
Alessandro
2020-07-24 7:29 AM
Unfortunatly no Alessandro, you cannot change the shunt resistance value.
Then the gain of the power board will be then different than the gain configured inside the firmware, and it will not work anymore.
And there is no way to tell the profiler that the shunt changed.
Best regards,
Claire
