2018-06-10 2:31 PM
IPM module STGIPQ3H60T has build-in NTC. How to configure the temperature sensing with build-in NTC for the FO?-SDK?
Thank you,
Artem
#foc-sdk #temperature-sensing #build-in-ntc2018-06-11 3:49 AM
Dear Artem,
Unfortunately, the FOC SDK does not support yet negative ramp. It will be added latter.
For the time being, you can use virtual temperature sensor (it will send always 25 deg) for debug purpose.
Cedric
2021-06-15 1:23 AM
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
