STM32 MCUs Motor control
GMA by ST Employee
  • 1838 Views
MCSDK 6.4.0 is out!
GMA by ST Employee
  • 4992 Views
Zied b. by ST Employee
  • 9744 Views
Resolved! Why is the STEVAL-SPIN3201 limited to 15 Arms?
Hi, I read in the Data Brief of the STEVAL-SPIN3201 module that it can ouput up to 15 Arms of current but I can't find in the schematic why that it. The mosfet used on the board (STD140N6F7) seems capable of higher current output.We want to port the ...
PBela.1 by Associate II
  • 1338 Views
Resolved! Encoder "reverse counting direction" checkbox not working in ST MC Workbench 5.4.3. What am I missing?
Hi all,I have been pulling my hair out trying different ways to reverse my encoder counting direction.The checkbox "reverse counting direction" in Speed Sensing section does not seem to make any difference. I am using Attolic TrueSTUDIO IDE, and the ...
Frakk by Associate II
  • 3290 Views
Resolved! how to turn off both complementary pwm at the same time
I am using STM32F4 to drive a 3 phase BLDC motor and i'm using TIM1 peripheral to generate 6-step PWM(complementary pwm) but when i change the configuration and i disable 1 channel it takes some time to go low which causing problems (you can check th...
mboua by Associate
  • 2753 Views
Resolved! Does MC_SDK require the use of coprocessor?
We are developing an application to drive dual PMSM motors with STM32H745 and FOC algorithms and resolver sensor. The inner current loops are executed at 10 kHz, PWM carrier frequency is set to 20 kHz. Is it feasible o run the entire application code...
LZhu.1 by Associate
  • 1302 Views
Resolved! Recommended setup for small motor position control?
I have a small BLDC motor with magnetic encoder (like this one https://www.aliexpress.com/item/33053552345.html) and would like to set up a position control. The NUCLEO-IHM03 comes pretty close https://www.st.com/content/st_com/en/products/evaluatio...
Martin294 by Associate III
  • 5594 Views
Resolved! Trapezoidal control for bldc drives
I am developing bldc drives using stm32f103c8t6 MCU. And by using inverter circuit we drive the bldc motor using stm32. Block diagram of drive is shown belowUsing register language, we coded logically for 6 step commutation. And that works fine.But ...
Bud by Associate III
  • 2413 Views
