STM32 MCUs Motor control
GMA by ST Employee
  • 1838 Views
MCSDK 6.4.0 is out!
GMA by ST Employee
  • 4992 Views
Zied b. by ST Employee
  • 9744 Views
STM Motor Control 6.3 - current sensing issue
Hello Community,I have a problem with the STM Motor Control Workbench 6.3. I have hardware for FOC motor control. For the current measurement, I am using three shunts with differential current measurement, integrated op-amps, and an external resistor...
kaps by Associate II
  • 10695 Views
  • 10 replies
MCSDK 6.4.1. FOC with hall sensor start up issues
Hello, I did a custom design based on EVLSPIN32G4-ACT, schematic is basically the same apart from board shape and connectors.The hardware is working in general, I successfully got my BLDC motor without an attached load spinning using sensor less spee...
BWI by Associate II
  • 1050 Views
Resolved! STSPIN32G4 Trace Pins
Hi,I want to use the Trace Interface on the STS32PING4, but I can't seem to find the correct Pins for it. I have found a general Overview of where the Pins would be located in the STM32G431 here (PE2-PE6):https://www.st.com/content/ccc/resource/train...
dmuth by Associate
  • 680 Views
