2025-11-16 2:27 AM
I want to use the Trace Interface on the STS32PING4, but I can't seem to find the correct Pins for it. I have found a general Overview of where the Pins would be located in the STM32G431 here (PE2-PE6):
But since the STM32G431 is integrated in the STSPING4, I don't know the mapping. Also in the Datasheet in the STSPING4, I can't find the Pin names TRACECK and TRACED0-TRACED3.
Greetings
dmuth
2025-11-17 2:12 AM
Hello @dmuth,
Pin mapping is available in the STSPIN32G4 Datasheet under the "4 pin description" chapter.
PE2 to PE6 TRACE feature pins are not included in the STSPIN32G4 package.
2025-11-17 2:12 AM
Hello @dmuth,
2025-11-17 2:48 AM
Thanks for the clarification. I thought the trace pins would be available, but just not documented in the datasheet. Then we have to figure out another way for tracing.
