2025-12-27 3:31 AM - last edited on 2025-12-29 3:00 AM by Andrew Neil
Split from Zephyr RTOS on Nucleo-F411RE ? - which has been answered.
This is a new question.
Hi T_Hamdi
Thank you for your response.
I have installed the Zephyr IDE and used the Blinky LED example. The firmware was flashed successfully; however, the LED is not glowing.
I have attached an image for your reference. Please take a look.
2025-12-29 2:24 AM
Hello @Kumar123,
I see in the image that the .hex file is flashed using the J-Link debugger. Do you have a J-Link connected to the board, or are you using the ST-Link included on the board?
