2022-02-01 6:16 PM
As long as the VDDUSB supply is from 3.0V to 3.6V and is the last to be applied and first removed (vs. VDD), there should be no issues?
2022-02-02 6:45 AM
Hello @JOkam.1
Yes, according to datasheet 3.9.1 Power supply schemes, VDDUSB = 3.0 to 3.6 V: external independent power supply for USB transceivers. The VDDUSB voltage level is independent from the VDD voltage.
Concerning Power-up/down sequence in this same chapter, check that you meet the requirements on VDD & VDDA (no contraints on VDDUSB).
BR,
Bruno
2022-02-02 9:31 PM
Thank you for the clarification.
