How to abort a HAL_I2C_Mem_Read_DMA()?
Hello community,I've a code that calls the function HAL_I2C_Mem_Read_DMA(), and I want to abort the operation under a certain condition. I tried the function HAL_I2C_Master_Abort_IT(), but it is not working. could you please help me find a way to abo...
Araqi.1 by Associate II
  • 1016 Views
HI, I have a problem with the example program provided by stmCUBE IDE and my board nucleo-H723ZG, the example program (LwIP_TCP_Echo_Server LwIP TCP Echo Server Application)
Hi,I have a problem with the example program provided by stmCUBE IDE and my board nucleo-H723ZG, the example program (LwIP_TCP_Echo_Server LwIP TCP Echo Server Application) contains inside a README. txt that explains how to run the example, but it is...
GNobi.1 by Associate II
  • 1819 Views
SPI Data Register Problem
Hi,​I`m using STM32G431 for practicing SPI protocol knowledge, but face some problem like below.​I use �?HAL_SPI_Transmit_IT】API to send (0x5A,0xA5) data out, but measure with Oscilloscope and figure out the wrong data.In �?SPI_TxISR_8BIT】show how d...
How DMA works for USB HS
I am wondering how DMA works for USB HS. As far as I know it is a "machine" to copy memory to another place. And how is it implemented for USB ? We have there a FIFO queue and from what I observed in the driver, the data from the FIFO are copied by t...
PPiór.1 by Associate III
  • 1441 Views
MSC device does not connect to windows.
Hello,​I'm trying MSC with Nucleo, MSC device does not connect to windows.What am I missing? [windows error] -cannot read device descriptor​[environment​] -STM32CubeIDE Version: 1.7.0 -NUCLEO-F411RE -STM32Cube FW_F4 V1.26.2 -​usb : Device_Only, Mass ...
take by Associate
  • 1007 Views
