2023-01-03 8:48 PM
2023-01-04 12:07 AM
Just copy the .pdf to your STM32 using Mass Storage Class and FATFS.
hth
KnarfB
2023-01-04 4:27 AM
The thing is with .pdf i am able to create a file but i am not able to open that file.
2023-01-04 5:14 AM
Check content in file manager or viewer. Check integrity and that it contains what your expect / wrote.
If you update on-the-fly generate a Media Changed Sense Code, so the PC Side OS will reread.
2023-01-04 7:15 AM
Pdf file open in note++
2023-01-04 7:17 AM
Without note++ , I m not able to open pdf file
2023-01-04 7:59 AM
Please fix the problem
2023-01-04 9:51 AM
Could it be that the PDF is not correctly constructed/written?
2023-01-04 9:53 AM
Not really my job, perhaps someone on your team can work on it, or a supervisor/manager for the project?
2023-01-04 10:58 AM
By Note++ you must mean Notepad++, right?
Notepad++ is a text editor and typically displays PDF only as a jumble of control characters - provided it is a standards-compliant PDF.
How did you create the PDF?
/Peter
